Model.CE_ReviewConnectors#
- Model.CE_ReviewConnectors(collection_set, operation_type, output_collection_set, consider_geom=True, consider_HAZ_elems=True, find_twince_option=0, filter_projection_entities=0)#
Reviews connectors according to user options.
- Parameters:
collection_set (CollectionSet) – The set of collections containing possibly multiple type of entities to review.
operation_type (hwString) –
The string for the type of operation to be performed: “findlinks”, “hide”, “isolate”, “isolateonly” and “show”,
To operate on twin connectors: “twince_hide”, “twince_isolate”, “twince_isolateonly” and “twince_show”.
output_collection_set (CollectionSet) – The set of collections containing possibly multiple type of entities onto which reviewed entities are placed.
consider_geom (bool) – Defines if geometry is also considered along with elements during show/hide/isolate operations. Valid values are true and false.
consider_HAZ_elems (bool) – Defines if HAZ (Heat Affected Zone) elements should also be considered during show/hide/isolate operations. The possible values are true and false.
find_twince_option (int) –
Find twin connectors according to:
1 - Minimum two links
2 - Exact links
filter_projection_entities (int) –
Filters links to the projection entities during show/hide/isolate operations, according to following options which are possible values:
0 - None
1 - Projection components
2 - Projection elements
3 - Projection and attached elements
Example#
Isolate connector with ID 5#import hm import hm.entities as ent model = hm.Model() InputCollectionSet = hm.CollectionSet(model) connectors = hm.Collection(model, ent.Connector, [5]) InputCollectionSet.set(connectors) OutputCollectionSet = hm.CollectionSet(model) model.CE_ReviewConnectors( collection_set=InputCollectionSet, operation_type="isolate", output_collection_set=OutputCollectionSet, consider_geom=False, consider_HAZ_elems=True, find_twince_option=2, filter_projection_entities=2 )
