Model.morphconstraintcreateangle#
- Model.morphconstraintcreateangle(scollection, type, name, n1, n2, n3, vec, angle, bound, color)#
Creates a model type constraint based on the angle between three nodes.
- Parameters:
scollection (Collection) – The collection containing the input shape entities.
type (int) –
0 - Measure angle node to node
1 - Measure angle using vector
name (hwString) – Name of morph constraint.
n1 (Entity) – The node entity defining the first end of angle.
n2 (Entity) – The node entity defining the the vertex of the angle.
n3 (Entity) – The node entity defining the second end of angle.
vec (hwTriple) – The hwTriple object defining the vector. User can also supply a Python list of three doubles.
angle (double) – Constrained angle.
bound (int) –
-1 - Greater than specified angle
0 - Equal to specified angle
1 - Less than specified angle
color (int) – The color of the constraint. Valid values are 1 through 64.
Example#
This function creates a model type constraint for the three selected nodes with the option of having those nodes measured in the plane that they lie in or perpendicular to a vector and the option of having the angle forced to be greater than, less than, or equal to the specified angle.#import hm import hm.entities as ent model = hm.Model() model.morphconstraintcreateangle( scollection=hm.CollectionByInteractiveSelection(model, ent.Shape), type=0, name="angle", n1=ent.Node(model,21), n2=ent.Node(model,22), n3=ent.Node(model,23), vec=[1.0, 0.0, 0.0], angle=45.0, bound=0, color=32, )
Note
The shapes on the
scollectionwill be used to force the model into compliance with the specified constraint, if possible.
