Model.morphmaptshpedge#
Model.morphmaptshpedge(dcollection, ecollection, scollection, lline, plane_normal, plane_base, line, points, niproj, iproj, clear, sym, con, type)#
Adds and edge domain perturbation to the current temporary shape.
Parameters:
  • dcollection (Collection) – The collection containing the domain entities.
  • ecollection (Collection) – The collection containing the element entities.
  • scollection (Collection) – The collection containing the surface entities.
  • lline (Entity) – Reserved for future use.
  • plane_normal (hwTriple) – The hwTriple object defining the plane normal components. User can also supply a Python list of three doubles.
  • plane_base (hwTriple) – The hwTriple object defining the base point components of the plane. User can also supply a Python list of three doubles.
  • line (EntityList) – The list containing the line entity
  • points (EntityList) – The list containing the point entities
  • niproj (int) –
    Direction of projection:
    0 - Along vector (iproj)
    1 - Normal to geom
    2 - Fit to line (if to a line or node list) normal to elems (if to a plane, surface, or mesh).
  • iproj (hwTriple) – The hwTriple object defining the vector components. User can also supply a Python list of three doubles.
  • clear (int) –
    Determine if/how to delete perturbations:
    0 - Add perturbation
    1 - Clear temporary and add perturbation
    2 - Reject last Model.morphmaptshpedge() operation
  • sym (int) – 0 - Do not use symmetry (only option)
  • con (int) – 1 - Use constraints (only option)
  • type (int) –
    The type of target to be mapped to.
    0 - Node list
    1 - Line
    2 - Plane
    3 - Surface
    4 - Elements
Example#
Add an edge domain perturbation to the domain selected interactively on the current temporary shape#
import hm
import hm.entities as ent
model = hm.Model()
model.morphmaptshpedge(
    dcollection=hm.CollectionByInteractiveSelection(model, ent.Domain),
    ecollection=hm.CollectionByInteractiveSelection(model, ent.Element),
    scollection=hm.CollectionByInteractiveSelection(model, ent.Surface),
    lline=hm.EntityList(ent.Line, hm.hwUIntList([])),
    plane_normal=[1.0, 0.0, 0.0],
    plane_normal_base=[1.0, 0.0, 0.0],
    line=[ent.Line(model, 32)],
    points=[ent.Point(model, 1), ent.Point(model, 2)],
    niproj=0,
    iproj=[1.0, 0.0, 0.0],
    clear=0,
    sym=0,
    con=1,
    type=1,
Note
This function is part of the map to geometry function which consists of multiple functions. This function is called any number of times, first with clear=1, then subsequently clear=0, followed either by one of the many morphmapto…() functions. If clear=2 then the last Model.morphmaptshpedge() function is rejected.
Type denotes the type of target to be mapped to. Either the plane, line, points, surface mark, or element collection must be filled with a valid entry corresponding to the type selected.
