Model.displayelementsbypropertybymark#
Model.displayelementsbypropertybymark(collection, mode, type)#
Displays elements that have either a direct, indirect or mixed property assignment for a selection of properties.
Parameters:
  • collection (Collection) – The collection containing the property entities to consider.
  • mode (hwString) –
    The mode to control the element display. Valid values are:
    on - Turn on the elements.
    off - Turn off the elements.
    reverse - Reverse the display of the elements (if off, turn on and if on, turn off).
    isolate - Isolate the display of the elements (turn off all others).
  • type (int) –
    The property assignment type to use for selecting the elements to display. Valid values are:
    0 - Direct property assignment.
    1 - Indirect property assignment.
    2 - Any property assignment.
Example#
Turn on the display of all elements with a direct property assignment for properties with IDs 1 - 4#
import hm
import hm.entities as ent
model = hm.Model()
model.displayelementsbypropertybymark(
    collection=hm.Collection(model, ent.Property, [1, 2, 3, 4]), mode="on", type=0
