Model.surfaceaddnodesfixed#
- Model.surfaceaddnodesfixed(surfacecollection, nodelist, tolerance, createplot)#
Adds meshing fixed points to a collection of surfaces, either by breaking edges or adding interior fixed points. The coordinates of the fixed points are supplied by a list of nodes.
- Parameters:
surfacecollection (Collection) – The collection containing the surface entities to modify.
nodelist (EntityList) – The list containing the nodes to use.
tolerance (double) – The closeness tolerance used to decide which points belong to a surface. A point can be added to more than one surface out of the
surfacecollection.createplot (int) –
Defines whether or not a plot element will be created between two points. It will be in the “^welds” component.
\(= 0\) - Do not create a weld element
\(\ne 0\) - Create a weld element
Example#
Add a point to surface with ID 190 whose coordinates correspond to those of node with ID 9#import hm import hm.entities as ent model = hm.Model() node9 = ent.Node(model, 9) model.surfaceaddnodesfixed( surfacecollection=hm.Collection(model, ent.Surface, [190]), nodelist=[node9], tolerance=0.5, createplot=1, )
