Model.hm_attributeindextypename#
- Model.hm_attributeindextypename(entity_type, entity_id, attribute_index)#
Returns the attribute type string of an indexed attribute on an entity.
- Parameters:
entity_type (EntityFullType) – The type of entity to query.
entity_id (unsigned int) – The ID of the entity.
attribute_index (int) – The index of the attribute owned by the queried entity (starting at 1).
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:type (str)
Example#
Get the attribute type number of the attribute with index 4 on property with ID 1#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_attributeindextypename( entity_type=ent.Property, entity_id=1, attribute_index=4 ) print("Type", result.type)
