Model.loadsupdatecurve#
- Model.loadsupdatecurve(collection, config, type, updatevector, comp1, comp2, comp3, comp4, comp5, comp6, updatemag, magnitude, update_system, system_id, transform_flag, updatecurve, curve_id, updatexscale, xscale, updatedisplaylocation, xlocation, ylocation, zlocation)#
Updates the magnitude, direction, coordinate system, and other information of selected loads entities.
When applying a force, the active components are
comp1,comp2, andcomp3, which represent a force x, y, and z-axis, respectively.When applying a moment, the active components are also
comp1,comp2, andcomp3, and represent the moment about the x, y, and z-axis, respectively.For constraints, all of the components are active unless they are set equal to -999999.0.
All of the other components of the constraints are active in the respective directions. For pressures, the active components are
comp1,comp2, andcomp3, which represent the x, y, and z-axis, respectively. To create a pressure that is normal to the element, set all components to zero.- Parameters:
collection (Collection) – The collection containing the loads entities to update.
config (int) –
The configuration of the load:
1 - Force
2 - Moment
3 - Constraints
5 - Temperature
6 - Flux
8 - Velocity
9 - Acceleration
type (int) – The type assigned to the load (as defined on the “load types” panel).
updatevector (int) – A variable that controls if the direction of the load should be updated.
comp1 (double) – Components of the load being applied. Representing force on x axis if force is being applied or moment about x axis if moment is being applied.
comp2 (double) – Components of the load being applied. Representing force on y axis if force is being applied or moment about y axis if moment is being applied.
comp3 (double) – Components of the load being applied. Representing force on z axis if force is being applied or moment about z axis if moment is being applied.
comp4 (double) – Components of the load being applied.
comp5 (double) – Components of the load being applied.
comp6 (double) – Components of the load being applied.
updatemag (int) – An integer variable that controls if the magnitude is updated.
magnitude (double) – The new value of magnitude of the load.
update_system (int) – A variable that controls if the system is updated.
system_id (unsigned int) – The ID of the local system.
transform_flag (int) – A simple integer variable that controls if the load is created in the local system.
updatecurve (int) – A flag to indicate whether the curve should be updated (0=no, 1=yes).
curve_id (unsigned int) – The ID of the new curve to use.
updatexscale (int) –
A flag to indicate whether the curve’s scale factor should be updated.
0 - No
1 - Yes
xscale (double) – The new value to use for scale factor.
updatedisplaylocation (int) –
A flag to indicate whether the curve’s display location should be updated.
0 - No
1 - Yes
xlocation (double) – The new display location in x axis (used only if
updatedisplaylocation=1)ylocation (double) – The new display location in y axis (used only if
updatedisplaylocation=1)zlocation (double) – The new display location in z axis (used only if
Example#
Update a force to use the curve with ID 7 to define its time - vary magnitude#import hm import hm.entities as ent model = hm.Model() model.loadsupdatecurve( collection=hm.Collection(model, ent.LoadForce, [4]), config=1, type=1, updatevector=0, comp1=0.0, comp2=0.0, comp3=0.0, comp4=0.0, comp5=0.0, comp6=0.0, updatemag=0, magnitude=0.0, update_system=0, system_id=0, transform_flag=0, updatecurve=1, curve_id=7, updatexscale=0, xscale=0.0, updatedisplaylocation=0, xlocation=0.0, ylocation=0.0, zlocation=0.0, )
