Model.reviewentitybymark#
- Model.reviewentitybymark(collection_set, color=0, showcomps=False, elements_off=False, geometry_off=False)#
Graphically reviews a collection set of entities.
- Parameters:
collection_set (CollectionSet) – The set of collections containing possibly multiple type of entities to review.
color (int) –
The color used to review the entities. Valid values are 1-64.
If specified as 0, entities will be reviewed with their respective entity color (not yet available).
showcomps (bool) – This indicates that components in which elements/geometry are referred will also be reviewed. If not provided, only specified elements/geometry are reviewed.
elements_off (bool) – This indicates that elements in the specified collectors should not be considered. If not provided, the default is to consider elements in the specified collectors.
geometry_off (bool) – This indicates that geometry in the specified collectors should not be considered. If not provided, the default is to consider geometry in the specified collectors.
Example#
Review the elements with IDs 1-100 use color 10#import hm import hm.entities as ent model = hm.Model() # Creating a collection set that contains the elements with IDs 1-100 filter_elements = hm.FilterByEnumeration(ent.Element, list(range(1, 101))) elements_collection = hm.Collection(model, filter_elements) CollectionSet = hm.CollectionSet(model) CollectionSet.set(elements_collection) model.reviewentitybymark(collection_set=CollectionSet, color=10, showcomps=False)
