Model.hwCfdSceneReverseAll#
Model.hwCfdSceneReverseAll(entity_type, consider_geom=1, consider_elems=1)#
This function is used to reverse the display of a mark of entities of a given entity type. This should be used in conjunction with the Model.hwCfdSceneShowHideIsolateEntity() and Model.hwCfdSceneShowAll() functions. This function is valid only for the CFD profile.
Parameters:
  • entity_type (EntityFullType) – The type of entity to modify. Valid entitiy type are parts, regions, surfaces and solids.
  • consider_geom (int) –
    0 - Do not consider the associated geometry
    1 - Consider the associated geometry. (default)
  • consider_elems (int) –
    0 - Do not consider the associated elements
    1 - Consider the associated elements. (default)
Example#
Hiding surfaces with IDs 1-10, reversing the display, then showing all entities#
import hm
import hm.entities as ent
model = hm.Model()
surf_col = hm.Collection(model,ent.Surface,list(range(1,11)))
model.hwCfdSceneShowHideIsolateEntity(function="hide",collection=surf_col)
model.hwCfdSceneReverseAll(entity_type=ent.Surface)
model.hwCfdSceneShowAll()
