Model.baroffsetupdate#
- Model.baroffsetupdate(collection, update_offset_a, offset_x_a, offset_y_a, offset_z_a, update_offset_b, offset_x_b, offset_y_b, offset_z_b)#
Updates the offsets in the global system for multiple bar and/or bar3 elements.
- Parameters:
collection (Collection) – The collection containing the bar or bar3 element entities to update.
update_offset_a (int) – If non-zero, the offsets at end a are updated.
offset_x_a (double) – The offset in the x-direction at end a. This is defined in the global system.
offset_y_a (double) – The offset in the y-direction at end a. This is defined in the global system.
offset_z_a (double) – The offset in the z-direction at end a. This is defined in the global system.
update_offset_b (int) – If non-zero, the offsets at end b are updated.
offset_x_b (double) – The offset in the x-direction at end b. This is defined in the global system.
offset_y_b (double) – The offset in the y-direction at end b. This is defined in the global system.
offset_z_b (double) – The offset in the z-direction at end b. This is defined in the global system.
Example#
Update bar elements with IDs 23 with offset vector at end a defined as (1.0, 2.0, 3.0) and at end b as (4.0, 5.0, 6.0)#import hm import hm.entities as ent model = hm.Model() elem = hm.Collection(ent.Element, [23]) model.baroffsetupdate( collection=elem, update_offset_a=1, offset_x_a=1.0, offset_y_a=2.0, offset_z_a=3.0, update_offset_b=1, offset_x_b=4.0, offset_y_b=5.0, offset_z_b=6.0 )
