Model.hm_getclosestpointsbetweenlinesurface#
Model.hm_getclosestpointsbetweenlinesurface(line, surf)#
Find the shortest distance between a line and a surface, and return line and surface points corresponding to this distance.
Parameters:
  • line (Entity) – The object describing the line entity.
  • surf (Entity) – The object describing the surface entity.
Returns:
  • hwReturnStatus - Status object
  • HmQueryResult - Result object containing the output values:
    • Keys valid for case which line and surf intersect
      • intersectionPoints (numpy.ndarray)
    • Keys valid for case which line and surf do not intersect
      • surfacePoint (numpy.ndarray)
      • linePoint (numpy.ndarray)
      • dist (double)
Examples#
Find the closest points between a line with ID 1 and a surface with ID 2 which intersect#
import hm
import hm.entities as ent
model = hm.Model()
_, result = model.hm_getclosestpointsbetweenlinesurface(
    line=ent.Line(model, 1), surf=ent.Surface(model, 2)
print("Intersection points coordinates:", result.intersectionPoints)
Find the closest points between a line with ID 1 and a surface with ID 2 which do not intersect#
import hm
model = hm.Model()
print("Surface point:", result.surfacePoint)
print("Line point:", result.linePoint)
print("Distance:", result.dist)
