Model.midsurface_remove_display_plate_sides#
- Model.midsurface_remove_display_plate_sides(plate_number, reserved1, reserved2)#
Deletes the two components that contain copies of the model surfaces belonging to two sides of a given plate.
- Parameters:
plate_number (int) – Specifies the plate number for which the plate side information is to be deleted.
reserved1 (int) – Reserved for future use. Must be set to 0.
reserved2 (int) – Reserved for future use. Must be set to 0.
Example#
Delete the plate information for the plate with plate number 127#import hm import hm.entities as ent model = hm.Model() model.midsurface_remove_display_plate_sides(plate_number=127, reserved1=0, reserved2=0)
