Model.meshline_create_from_points#
Model.meshline_create_from_points(entitylist, reserved1, reserved2, reserved3, reserved4)#
Creates meshlines from a node list.
Parameters:
  • entitylist (EntityList) – A list containing the node entity objects.
  • reserved1 (int) – Reserved for future use. Must be set to 0.
  • reserved2 (int) – Reserved for future use. Must be set to 0.
  • reserved3 (double) – Reserved for future use. Must be set to 0.
  • reserved4 (double) – Reserved for future use. Must be set to 0.
Example#
Create meshlines from nodes with IDs 470 , 480 , 475 and 485#
import hm
import hm.entities as ent
model = hm.Model()
node_list = [
    ent.Node(model, 470),
    ent.Node(model, 480),
    ent.Node(model, 475),
    ent.Node(model, 485),
model.meshline_create_from_points(
    entitylist=node_list, reserved1=0, reserved2=0, reserved3=0, reserved4=0
