Model.draglinetoformsurface#
Model.draglinetoformsurface(linelist, entitylist, direction_vector, distance, solid_stitch=0)#
Drags trimmed lines to create a surface, and optionally, prepares it for immediate use within the automesher. It can also identify a region in the shape of a dragged surface for the automesher to use under the mesh without surface option.
Parameters:
  • linelist (EntityList) – The list of line entities to be dragged.
  • entitylist (EntityList) – The list node entities which lie on the lines in the linelist, which will be used to trim the line during surface creation.
  • direction_vector (hwTriple) – The direction vector to drag the lines.
  • distance (double) – The distance to drag the lines.
  • solid_stitch (int) –
    0 - Created surface will not be stitched to a solid.
    1 - Created surface will be stitched to a solid.
Example#
Drag the lines with IDs 1, 2, trimmed by the nodes with IDs 29 and 30, -100.0 units in the direction of the y-axis, create a surface but no elements#
import hm
import hm.entities as ent
model = hm.Model()
# The model.surfacemode(mode=4) tells HyperMesh not to pass the information on to the automesher for element creation.
Line1 = ent.Line(model, 1)
Line2 = ent.Line(model, 2)
node1 = ent.Node(model, 29)
node2 = ent.Node(model, 30)
model.draglinetoformsurface(
    linelist=[Line1, Line2],
    entitylist=[node1, node2],
    direction_vector=[0.0, 1.0, 0.0],
    distance=-100.0,
