Model.displaycollectorsbymark#
Model.displaycollectorsbymark(collection, mode, elements, geometry)#
Changes the display state of collectors in a collection.
Parameters:
  • collection (Collection) – The collection containing the entities to change their display state.
  • mode (hwString) –
    The mode being performed, defined by the following:
    on - All collectors are turned on.
    all - All collectors are turned on.
    off - All collectors are turned off.
    none - All collectors are turned off.
    toggle - All collectors are toggled (visible become invisible and vice-versa).
    reverse - All collectors are toggled (visible become invisible and vice-versa).
  • elements (int) –
    Indicates if elements within collectors are to be turned on or off.
    0 - No
    1 - Yes
  • geometry (int) –
    Indicates if geometry within collectors are to be turned on or off.
    0 - No
    1 - Yes
Example#
Turn the elements on in the components named “ fender “ , “ box “ and “ bolt “ , and keep the geometry as it is#
import hm
import hm.entities as ent
model = hm.Model()
# Creating a collection that contains the components
components_collection = hm.Collection(
    model, ent.Component, "Name=fender OR Name=box OR Name=bolt"
model.displaycollectorsbymark(
    collection=components_collection, mode="on", elements=1, geometry=0
