Model.freebodysectiondisplacementtable#
- Model.freebodysectiondisplacementtable(freebodysection_ids, subcase_ids, freenode, displacement=0, resolvein_sys=0, resultID=Entity(), rotation=0, tolerance=0.0001, userSysID=Entity())#
Creates an FBD displacement summary table. This queries the GPF, Applied, SPC and MPC data from the result entity on a freebodysection.
- Parameters:
freebodysection_ids (EntityList) – A list containing the freebodysection entity objects.
subcase_ids (hwTripleIList) – The subcase details supplied as an array. Values are specified as <resultfile_id>_<subcase_id>_<step_id>, with each list separated by a comma.
freenode (int) – Currently must be set to 2. This is a mandatory argument.
displacement (unsigned int) –
0 - Applied forces are not participating in the FBD calculation (default)
1 - Applied forces are participating in the FBD calculation
resolvein_sys (unsigned int) –
1 - Resolve in global system
2 - Resolve in user system
3 - Free body section system
resultID (Entity) – The object describing the result entity.
rotation (unsigned int) –
0 - SPC forces are not participating in the FBD calculation (default)
1 - SPC forces are participating in the FBD calculation
tolerance (double) – The tolerance to limit the values. (Default is 0.00001)
userSysID (Entity) – The object describing the system entity when
resolvein_sys=2.
Example#
Create an FBD summary table#import hm import hm.entities as ent model = hm.Model() model.freebodysectiondisplacementtable( freebodysection_ids=[ent.Freebodysection(model, f) for f in range(1,4)], subcase_ids=[2_1_0, 2_2_0], freenode=2, displacement=1, resolvein_sys=1, resultID=ent.Result(model, 1), rotation=1, tolerance=0.0001, userSysID=ent.System(model, 1) )
