Model.hm_flangedetectioninit#
Model.hm_flangedetectioninit(collection, consider_geom=INT_MAX)#
Initializes the flange detection module. This must precede any calls to other hm_flangedetection APIs, and must be followed by a call to Model.hm_flangedetectionend().
“Major” database changes made while inside of the flange detection module will invalidate and delete any results.
Parameters:
  • collection (Collection) – The collection containing the entities to find flanges for. Valid entities are components, surfaces and elements.
  • consider_geom (int) –
    Used when the entity of the entities in the collection is components:
    0 - Use elements from the comps (default if not specified)
    1 - Use geometry from the comps
Returns:
Example#
Find 2D flanges from elements in all components , use a min width of 2 , a max width of 20 and a feature angle of 20 , and write out all flange details to a file named C:/temp / flanges.txt#
import hm
import hm.entities as ent
model = hm.Model()
flangesfile = open("C:/temp/flanges.txt", "w")
comps = hm.Collection(model, ent.Component)
model.hm_flangedetectioninit(collection=comps)
model.hm_flangedetectionsetparams(max_width=20.0, min_width=2.0, feature_angle=20.0)
model.hm_flangedetectionfindflanges(find=1)
_, result = model.hm_flangedetectiongetnumberofflanges()
n=result.numberOfFlanges
if n > 0:
    flangesfile.write(f"Number of flanges = {n}\n")
    flangesfile.write("Flanges details \n")
    for i in range(0,n):
        _, result = model.hm_flangedetectiongetflangedetails(index=i)
        entityType = result.entityType
        dimension = result.dimension
        detectionType = result.detectionType
        flangeEntityIDs = result.flangeEntityIDs
        freeBoundaryEntityIDs = result.freeBoundaryEntityIDs
        connectedBoundaryEntityIDs = result.connectedBoundaryEntityIDs
        minWidth = result.minWidth
        maxWidth = result.maxWidth
        length = result.length
        hasHoles = result.hasHoles
        isInfinite = result.isInfinite
        Details = [
            entityType,
            dimension,
            detectionType,
            flangeEntityIDs,
            freeBoundaryEntityIDs,
            connectedBoundaryEntityIDs,
            minWidth,
            maxWidth,
            length,
            hasHoles,
            isInfinite ]
        flangesfile.write(f"details = {Details}\n")
        print(i)
        status, result = model.hm_flangedetectiongetflangemidline(index=i,offset_distance=5.0)
        print("pointCoordinates",result.pointCoordinates)
        Coordinates = result.pointCoordinates
        for points in Coordinates:
            midPoint=points.midPoint
            flangesfile.write(f"midline = {midPoint}\n")
    model.hm_flangedetectionfindmates(max_search_dist=10.0, min_search_dist=0.0)
    _, result = model.hm_flangedetectiongetnumberofmatinggroups()
    m = result.numberOfMatingGroups
    if m>0:
        for i in range(0,m):
            _,result = model.hm_flangedetectiongetmatinggroupdetails(index=i)
            matingGroupDetails = result.matingGroupDetails
            for details in matingGroupDetails:
                memberType = details.memberType
                memberContents = details.memberContents
                flangesfile.write(f"memberType = {memberType}\n")
                flangesfile.write(f"memberContents = {memberContents}\n")
    else:
        flangesfile.write("Flange mates not detected.\n")
else:
    flangesfile.write("Flanges not detected.\n")
model.hm_flangedetectionend()
flangesfile.close()
