Model.surfacecreatedraglinealongline#
- Model.surfacecreatedraglinealongline(lines_collection, lines_list, method, options, comp_mode, node_entity, replane_normal, replane_base, solid_stitch=0)#
Creates surface(s) by dragging section lines(s) along a drag line. Lines in the line list are combined into a single line L, called the drag line. The direction of the drag line is determined by choosing its start point, S, as the closest end of the line to the section line vertices.
node_entity,refplane_normal,refplane_normal_basearguments are optional and determines how the input lines are transformed before drag.The reconfiguration of the geometries before the drag is done as follows. Let P be the point referred by the
node_entity, N be the normal and B be the base point of the refplane and T be the tangent vector of drag line at S. First, section lines are translated by the direction vector PB. If Bit3 of the options is not set, then, the section lines are rotated by the rotation from vector N to vector T. Also, the drag line is translated by the direction vector SB. The drag is applied to along this line L. So, if P is selected on a section line, the new location of P is going to be at B. Moreover, if P is one of the vertex points of the section lines, one gets an exact geometric copy of the drag line at B, no matter which drag method is chosen. This is because, prior to drag, P is moved to B and B moves on drag line since it coincides with the start point of the drag line L.If
node_entityis not given, it is chosen as the same point as S, the start of the drag line. This means, with the default value ofnode_entity, the drag line is not transformed.If the reference plane is not given, their default values are B at P and N=T. This means, with the default value of transformation plane, the section lines are not transformed prior to drag.
Note that, the location of P is not important if fixed frame method is chosen with no transformation plane, since each point on the section surface traces an exact geometric copy of the drag line in fixed frame method.
- Parameters:
lines_collection (Collection) – The collection containing the line entities to drag.
lines_list (EntityList) – A list containing the entity objects that will be used from the drag lines. The first line in this list determines the direction of the drag, which is also shown to the user on the screen. If the drag line has corners, then the new surfaces are split at those locations.
method (int) –
Parameter specifying the method of how the drag is performed. Valid options are:
0 - Fixed frame.
1 - Follow the drag line only along its tangent direction.
2 - Follow the drag line along its Frenet frame.
options (int) –
Flags that indicate different modes for the drag.
Bit values are used and the value is calculated as (Bit0 + 2*Bit1 + 4*Bit2 + 8*Bit3). Valid Bit options are:
Bit0
Drag along the direction of the drag line or along the opposite one. Valid values are:
0 - Drag along the direction of the drag line.
1 - Drag along the opposite direction of the drag line.
Bit1
Merge input lines. Valid valuse are:
0 - Do not merge input lines. A surface is created for each input line.
1 - Merge input lines into smooth lines when possible. A surface is created for each group that forms tangentially continuous lines.
Bit2
Use of ref_plane input. Valid values are:
0 - Use the ref_plane input.
1 - Do not use the ref_plane input. Instead, use its default values.
Bit3
Use of the whole ref_plane for transformation. Valid values are:
0 - Use the whole ref_plane for transformation if it is given.
1 - Use the only the base point of the reference plane, set the normal as the tangent of the drag line at drag start point.
Show Bit value calculator
Radio Button Table Option Name Value Drag along the direction of the drag line or along the opposite one (Bit0) Merge input lines (Bit1) Use of ref_plane input (Bit2) Use of the whole ref_plane for transformation (Bit3) Calculated argument value: 0 comp_mode (int) –
Parameter specifying how entities are organized into components:
0 - Surfaces are created in the current component.
1 - Surfaces are created in the same component as the selected lines. The result is not predictable if the lines are originally in different components.
node_entity (Entity) – The object describing the node entity to be used as a reference point while determining how the surfaces are transformed prior to drag.
replane_normal (hwTriple) – The hwTriple object defining the plane normal components. User can also supply a Python list of three doubles.
replane_base (hwTriple) – The hwTriple object defining the base point components of the plane. User can also supply a Python list of three doubles.
solid_stitch (int) –
0 - Created surface will not be stitched to a solid.
1 - Created surface will be stitched to a solid.
Example#
Drag section - lines with IDs 39 , 401 and 388 along the line that is formed by combine lines with IDs 37 and 25 , use the fixed frame method . Assume that you want to drag along the direction opposite to the direction of line with ID 37 and want to merge the input section lines into smooth line groups when possible . Moreover , you want the resultant surfaces to be organized in the component of the lines . Then ,options = 1 + 2 = 3, andcomp_mode = 1. Use a reference node with ID 12 , which happen to lie on one of the section lines , and a reference plane . The surfaces created will be in such a way that the new location of the point on which node with ID 12 located , will be at the base point ( 2678.0 , -737.7 , 548.1 ) of the reference plane .#import hm import hm.entities as ent model = hm.Model() Line1 = ent.Line(model, 39) Line2 = ent.Line(model, 388) Line3 = ent.Line(model, 401) model.surfacecreatedraglinealongline( lines_collection=hm.Collection(model, ent.Line, [37, 25]), lines_list=[Line1, Line2, Line3], method=0, options=3, comp_mode=1, node_entity=ent.Node(model,12), replane_normal=[1.0, 1.0, 1.0], replane_base=[2678.0, -737.7, 548.1], )
