Model.surfacecreatedragnodesalongline#
Model.surfacecreatedragnodesalongline(sectionnodelist, draglinelist, method, options, comp_mode, node_entity, refplane_normal, refplane_base, solid_stitch=0)#
Creates surface(s) by dragging a section line along a line. The section line is constructed smoothly from the nodes in sectionnodelist. The direction of the drag line is determined by choosing its start point, S, as the closest end of the line to the section line vertices.
node_entity , refplane_normal, refplane_normal_base, arguments are optional and determines how the input lines are transformed before drag.
The reconfiguration of the geometries before the drag is done as follows. Let P be the point referred by the node_entity, N be the normal and B be the base point of the reference plane and T be the tangent vector of drag line at S. First, section lines are translated by the direction vector PB. If Bit3 of the options is not set, then the section lines are rotated by the rotation from vector N to vector T. Also, the drag line is translated by the direction vector SB. The drag is applied to along this line L. So, if P is selected on a section line, the new location of P is going to be at B. Moreover, if P is one of the vertex points of the section lines, one gets an exact geometric copy of the drag line at B, no matter which drag method is chosen. This is because, prior to drag, P is moved to B and B moves on drag line since it coincides with the start point of the drag line L.
If node_entity is not given, it is chosen as the same point as S, the start of the drag line. This means, with the default value of node_entity, the drag line is not transformed.
If the reference plane is not given, their default values are B at P and N=T. This means, with the default value of transformation plane, the section lines are not transformed prior to drag. The location of P is not important if fixed frame method is chosen with no transformation plane, since each point on the section surface traces an exact geometric copy of the drag line in fixed frame method.
Parameters:
  • sectionnodelist (EntityList) – A list containing the entity objects.
  • draglinelist (EntityList) – A list containing the entity objects.
  • method (int) –
    Parameter specifying the method of how the drag is performed. Valid options are:
    0 - Fixed frame
    1 - Follow the drag line only along its tangent direction
    2 - Follow the drag line along its Frenet frame
  • options (int) –
    Flags that indicate different modes for the drag.
    Bit values are used and the value is calculated as (Bit0 + 4*Bit2 + 8*Bit3). Note that Bit1 is not used.
    Valid Bit options are:
    Bit0
    Drag along the direction of the drag line or along the opposite one. Valid values are:
    0 - Drag along the direction of the drag line.
    1 - Drag along the opposite direction of the drag line.
    Bit2
    Use of ref_plane input. Valid values are:
    0 - Use the ref_plane input.
    1 - Do not use the ref_plane input. Instead, use its default values.
    Bit3
    Use of the whole ref_plane for transformation. Valid values are:
    0 - Use the whole ref_plane for transformation if it is given.
    1 - Use the only the base point of the reference plane, set the normal as the tangent of the drag line at drag start point.
    Show Bit value calculator
    Radio Button Table
    Option Name Value
    Drag along the direction of the drag line or along the opposite one (Bit0)
    Use of ref_plane input (Bit1)
    Use of the whole ref_plane for transformation (Bit2)
    Calculated argument value: 0
  • comp_mode (int) –
    Parameter specifying how entities are organized into components:
    0 - Surfaces are created in the current component.
    1 - Surfaces are created in the same component as the selected lines. The result is not predictable if the lines are originally in different components.
  • node_entity (Entity) – The object describing the node entity to be used as a reference point while determining how the surfaces are transformed prior to drag.
  • refplane_normal (hwTriple) – The hwTriple object defining the plane normal components. User can also supply a Python list of three doubles.
  • refplane_base (hwTriple) – The hwTriple object defining the base point components of the plane. User can also supply a Python list of three doubles.
  • solid_stitch (int) –
    0 - Created surface will not be stitched to a solid.
    1 - Created surface will be stitched to a solid.
Example#
Drag nodes with IDs 5, 6, 7, and 8 along the line that is formed by combine lines with IDs 37 and 25, use the fixed frame method. Assume that you want to drag along the direction opposite to the direction of line with ID 37. Moreover, you want the resultant surfaces to be organized in the component of the lines. Then, options=1, and comp_mode=1. Use a reference node with ID 12 with some reference plane. The surfaces created will be in such a way that the new location of the point on which node with ID 12 located, will be at the base point (2678.0, -737.7, 548.1) of the reference plane.#
import hm
import hm.entities as ent
model = hm.Model()
node1 = ent.Node(model, 5)
node2 = ent.Node(model, 6)
node3 = ent.Node(model, 7)
node4 = ent.Node(model, 8)
Line1 = ent.Line(model, 37)
Line2 = ent.Line(model, 25)
model.surfacecreatedragnodesalongline(
    sectionnodelist=[node1, node2, node3, node4],
    draglinelist=[Line1, Line2],
    method=0,
    options=3,
    comp_mode=1,
    node_entity=ent.Node(model, 12),
    refplane_normal=[1.0, 1.0, 1.0],
    refplane_base=[2678.0, -737.7, 548.1],
