Model.hm_getunusedoremptyentities_byname#
Model.hm_getunusedoremptyentities_byname(mode, outputCollectionSet, type, name)#
Returns empty or unused entities, and places them on a collection. The return value is a list of lists. Each sub-list contains the empty or unused entity type as its first value, and the found entity IDs as the remainder of the sub-list.
Parameters:
  • mode (hwString) – The query mode. Valid values are empty, unused, and unusedempty.
  • outputCollectionSet (CollectionSet) – The set of collections containing possibly multiple type of entities.
  • type (EntityFullType) – The type of entity to query. If not specified, all entities in the database are queried.
  • name (hwString) – The name of the single entity to query.
Returns:
Example#
Get the the empty sets out of set entity with name “node_output”#
import hm
import hm.entities as ent
model = hm.Model()
output = hm.CollectionSet(model)
_, resultlist = model.hm_getunusedoremptyentities_byname(
    mode="unused",
    outputCollectionSet=output,
    type=ent.Set,
    name="node_output"
for result in resultlist:
    print("entityType:", result.entityType)
    print("entityIds:", result.entityIds)
