Model.morphhandlecreatenodesnodom#
- Model.morphhandlecreatenodesnodom(collectionnode, dcollectionhandle, name)#
Creates handles at nodes on collection with no domain given.
- Parameters:
collectionnode (Collection) – The collection containing the node entities to create the handles at.
dcollectionhandle (Collection) – The collection containing the dependent handle entities. The collection maybe empty.
name (hwString) – Name of handle(s) to be created
Example#
Create handles at the nodes on the collection with dependencies on the handles on the collection#import hm import hm.entities as ent model = hm.Model() model.morphhandlecreatenodesnodom( collectionnode=hm.CollectionByInteractiveSelection(model, ent.Node), dcollectionhandle=hm.Collection(model, ent.Handle, populate=False), name="bob", )
Note
The domains on which the handles are created are determined automatically based on the node selected. Domains which share a common node are selected in the following order: edges, 2D domains, 3D domains, 1D domains, general domains, and global domains. Handles touching morph volume nodes will not be assigned to any domain.
The name does not need to be unique since this function will create a unique name for each new handle by adding numbers after the name.
