Model.hm_getmeshvolumesinfo#
Model.hm_getmeshvolumesinfo(collection, mode=0)#
Returns the number of volumes and multiple lists containing the elements and volume indices for each input element.
Parameters:
  • collection (Collection) – The collection containing the element entities to find volumes for.
  • mode (int) –
    Mode for internal voids. Valid options are:
    0 - internal voids considered as “voids” and do not make a new volume
    1 - internal voids considered as new volumes
Returns:
  • hwReturnStatus - Status object
  • HmQueryResult - Result object containing the output values:
    • volumes_count (unsigned int) - The number of identified volumes.
    • volumes_per_elem (HmQueryResultList) - Result list object containing HmQueryResult objects with the following output data; element, volume_i, volume_j. The keys represents the shell element and a pair of volumes of corresponding element sides. The first volume (volume_i) corresponds to the volume on the shell element side with normal pointing out. A volume of 0 represents free space (no volume).
      • element (Entity) - Entity Type: Element
      • volume_i (unsigned int)
      • volume_j (unsigned int)
Example#
Orient all shell elements so that the normal points toward the inside of the volume with the smallest ID ( or inside if there is only one volume )#
import hm
import hm.entities as ent
model = hm.Model()
# Creating a list for elements to be reversed their normal \
# toward the inside if there is only one volume.
elem_collection = hm.CollectionByDisplayed(model, ent.Element)
_, result = model.hm_getmeshvolumesinfo(collection=elem_collection)
num_volumes = result.volumes_count
volumes_list = result.volumes_per_elem
reverse_list = list()
for resObj in volumes_list:
    elem = resObj.element
    vol1 = resObj.volume_i
    vol2 = resObj.volume_j
    if vol1 > vol2:
        reverse_list.append(elem)
if len(reverse_list) != 0:
    reverse_elem_collection = hm.Collection(reverse_list)
    model.normalsreverse(collection=reverse_elem_collection, size=1 ** (-10))
