Model.hm_comparegettransformationmatchentities#
- Model.hm_comparegettransformationmatchentities(transformation_index, match_index, match_location)#
Returns the entity IDs associated with a specific transformation and match. This must be preceded by a call to a relevant hm_compareentities function.
- Parameters:
transformation_index (int) – The index of the transformation to query, starting with 0. The number of transformations can be found using
Model.hm_comparegettransformationcount().match_index (int) – The index of the match corresponding to the
transformation_indexto query, starting with 0. The number of matches can be found usingModel.hm_comparegettransformationmatchcount().match_location (int) –
The location of the match to query. Valid values are:
1 - Source entities
2 - Target entities
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:entityIds (numpy.ndarray)
Example#
Find the source entity IDs for transformation 0 for the recursive comparison of surfaces with IDs 1 - 20 and 101 - 120#import hm import hm.entities as ent model = hm.Model() surf1 = hm.Collection(model, ent.Surface, list(range(1, 21))) surf2 = hm.Collection(model, ent.Surface, list(range(101, 121))) model.hm_compareinit() model.hm_compareentitiesrecursive( source_surfaces=surf1, target_surfaces=surf2, tolerance=0.1, result_type=2, review_results=False, ) _, result = model.hm_comparegettransformationmatchentities( transformation_index=0, match_index=5, match_location=1 ) source_entities = result.entityIds print("source_entities", source_entities) model.hm_compareend()
