Model.addfacestocontactsurfusingfacenumber#
- Model.addfacestocontactsurfusingfacenumber(name, collection, face_number, reverse_normals, element_id, use_element_id)#
Adds elements using the face number to a contact surface.
- Parameters:
name (hwString) – The name of the contact surface to update. User can directly supply a Python string.
collection (Collection) – The collection containing the element entities to add.
face_number (int) – The face number of the element (starting from
0).reverse_normals (int) –
Valid values are:
0 - Create contact surface along element normal.
1 - Create contact surface opposite element normal.
element_id (int) – The single element ID to use.
use_element_id (int) –
Valid values are:
0 - Use collection.
1 - Use element_id.
Example#
Add elements with IDs 1 - 100 use face number 2 to contactsurf “ test “#import hm import hm.entities as ent model = hm.Model() # One-line version of collection using FilterByEnumeration elem_col = hm.Collection(model, ent.Element, list(range(1, 101))) # ID 1-100 model.addfacestocontactsurfusingfacenumber( name="test", collection=elem_col, face_number=2, reverse_normals=0, element_id=0, use_element_id=0, )
