Model.segmentsetaddfaces#
Model.segmentsetaddfaces(name, elem_collection, node_collection, break_angle, reverse_normals, face_or_edge)#
Adds elements using the face/edge option to a segment set.
Parameters:
  • name (hwString) – Name of the segment set to update.
  • elem_collection (Collection) – The collection containing the solid element entities to add.
  • node_collection (Collection) – The collection containing the node entities that define an edge or a face of an element.
  • break_angle (double) – The break angle for finding adjacent elements.
  • reverse_normals (int) –
    Create segment set:
    0 - Along element normal
    1 - Opposite element normal
  • face_or_edge (int) –
    Create segment set:
    0 - On edge
    1 - On face
    10 - On edge for shells, do not consider break angle
    11 - On face for solids, do not consider break angle
    20 - On edge for shells, consider hidden entities
    21 - On face for solids, consider hidden entities
    30 - On edge for shell, do not consider break angle, consider hidden entities
    31 - On face for solid, do not consider break angle, consider hidden entities
Example#
Add elements with IDs 1 - 100 with faces defined by nodes with IDs 1 - 5 to the segment set * “ test “ * with a break_angle=30.0#
import hm
import hm.entities as ent
model = hm.Model()
# Creating a collection that contains the elements to add
filter_add_elements = hm.FilterByEnumeration(ent.Element, list(range(1, 101)))
add_elements_collection = hm.Collection(model, filter_add_elements)
# Creating a collection that contains the nodes that define the faces
filter_nodes = hm.FilterByEnumeration(ent.Node, list(range(1, 6)))
node_define_collection = hm.Collection(model, filter_nodes)
model.segmentsetaddfaces(
    name="test",
    elem_collection=add_elements_collection,
    node_collection=node_define_collection,
    break_angle=30.0,
    reverse_normals=0,
    face_or_edge=1,
