Model.CE_ConnectorCombine#
- Model.CE_ConnectorCombine(collection, tolerance, ignore_links=0, overlaps=100)#
Combines connectors. Locates connectors that are considered subsets of other connectors within a given tolerance, makes supersets from the connectors having at least one common link entity, and deletes the original subsets.
To make a combination possible, connectors must have at least one shared link entity.
Note
Currently supported for connectors located at geometric points only.
- Parameters:
collection (Collection) – The collection containing the connector entities to combine.
tolerance (double) – The maximum distance between two connectors that are considered to be duplicates.
ignore_links (int) – Reserved for future development. Must be set to 0.
overlaps (int) – Reserved for future development. Must be set to 100.
Example#
Combine displayed connectors within 0.05 tolerance#import hm import hm.entities as ent model = hm.Model() connectors = hm.CollectionByDisplayed(model, ent.Connector) model.CE_ConnectorCombine(collection=connectors, tolerance=0.05)
