Model.CE_ConnectorCreateByMark#
Model.CE_ConnectorCreateByMark(collection, ce_style, num_links, link_collection, link_elems_geom='', link_rule='', relink_rule='', tol_flag=0, tol=0, line_preserve_nodes=0, line_spacing=1.0, line_density=0, line_offset_flag=0, line_offset=0, start_offset=0.0, end_offset=0.0, retain_line=1, seam_area_group=0, ce_nonnormal=0, area_width=0.0, area_offset=0.0, area_mesh_type=0, area_mesh_size=10.0, loc_as_link=0, ce_extralinknum=0, ce_hexaoffsetcheck=0, area_linecombine=0.0, ce_normal_link=0, ce_link_option=0, ce_normal_angle=0.0, ce_center_pos=0.0, ce_boltmindiameter=0.0, ce_boltmaxdiameter=0.0, ce_boltcenterset=0, ce_num_center=0, ce_maxlinkupto=0, line_combine_option='', smooth_curve_nodes=0, ce_boltcenter=0, ce_config_name='', ce_engg_name='', ce_seam_vertex_angle=45.0, line_preserve_joints=0, ce_seam_discontinuity=0, eline_flag=False, disable_multilinks=0, grouplinks=False, main_link_count=0, main_link_ids=hwIntList())#
Creates a certain style of connector at locations specified by a collection, with certain rules and details.
Parameters:
  • collection (Collection) –
    The collection containing the entities that specify the location to create connectors. Valid entities are:
    points Valid for Spot, Bolt, and Apply Mass connectors.
    nodes Valid for Spot, Bolt, and Apply Mass connectors.
    lines Valid for Spot, Bolt, and Seam connectors.
    elements Valid only for Area connectors.
    surfaces Valid only for Area connectors.
  • ce_style (hwString) – The style of connectors to create. Valid values are apply “mass”, “area”, “bolt”, “seam”, and “spot”.
  • num_links (int) – The number of links to use.
  • link_collection (Collection) – The collection containing the entities to create links for. Valid entities components (for spot, bolt, seam, area or apply_mass), elements (for spot or apply_mass), nodes (for spot or apply_mass), surfaces (for spot, seam or area) and tags (for spot or apply_mass)
  • link_elems_geom (hwString) – Specifies whether to connect elements (elems) or geometry (geom). Default elems.
  • link_rule (hwString) – The link rule. Valid values are “now”, “at_fe_realize” or “none”. (Default “none”)
  • relink_rule (hwString) – The relink rule. Valid values are “id”, “name” or “none”. (Default “none”)
  • tol_flag (int) –
    0 - Do not offset tol. (Default)
    1 - Use tol.
  • tol (double) – Add entities as links only within this distance of the specified location. (Default 0.0)
  • line_spacing (double) – The spacing for spot or seam connectors on lines. (Default 1.0)
  • line_density (int) – The density for spot or seam connectors on lines. (Default 0.0)
  • line_offset_flag (int) –
    0 - Do not offset connectors. (Default)
    1 - Offset connectors.
  • line_offset (double) – Offset value from the ends of the line for spot or seam connectors on lines. (Default 0.0)
  • seam_area_group (int) –
    Group flag for seam or area connector.
    0 - No (default).
    1 - Yes.
  • area_width (double) – Width of area connectors created from node or line lists. (Default 1.0)
  • area_offset (double) – Offset area connectors created from node or line lists from the selected location by this value. (Default 0.0)
  • area_mesh_type (int) –
    The mesh type for area connectors when using surfs as the location.
    0 - trias
    1 - quads
    2 - mixed
    3 - right trias
  • area_mesh_size (double) – The mesh size for area connectors when using surfs as the location. (Default 10.0)
  • ce_nonnormal (int) –
    0 - Normal projection
    1 - Non-normal projection.
  • start_offset (double) – The offset distance at the start of the combined line.
  • end_offset (double) – The offset distance at the end of the combined line.
  • retain_line (int) – Reserved for future development
  • line_preserve_nodes (int) – Reserved for future development
  • loc_as_link (int) – Reserved for future development
  • ce_extralinknum (int) – Reserved for future development
  • ce_hexaoffsetcheck (int) – Reserved for future development
  • area_linecombine (double) – Reserved for future development
  • ce_normal_link (int) – Reserved for future development
  • ce_link_option (int) – Reserved for future development
  • ce_normal_angle (double) – Reserved for future development
  • ce_center_pos (double) – Reserved for future development
  • ce_boltmindiameter (double) – The minimum diameter for a hole to be accepted as a bolt hole.
  • ce_boltmaxdiameter (double) – The maximum diameter for a hole to be accepted as a bolt hole.
  • ce_boltcenterset (int) – Reserved for future development
  • ce_num_center (int) – Reserved for future development
  • ce_maxlinkupto (int) – Reserved for future development
  • line_combine_option (hwString) –
    The combine option for combining the two or more line connectors:
    combine_smooth - Combines lines/connector with smooth
    curvecombine_straight - Combines lines/connectors with straight
    curvecombine_midline - Combines two lines/connectors as one midline connector
  • smooth_curve_nodes (int) – Reserved for future development
  • ce_boltcenter (hwTriple) – Reserved for future development
  • ce_config_name (hwString) – The name of the bolt config.
  • ce_engg_name (hwString) – Reserved for future development
  • ce_seam_vertex_angle (double) – Reserved for future development
  • line_preserve_joints (int) – Reserved for future development
  • ce_seam_discontinuity (int) – Reserved for future development
  • eline_flag (bool) – Reserved for future development
  • disable_multilinks (int) – Reserved for future development
  • grouplinks (bool) – Reserved for future development
  • main_link_count (int) – Reserved for future development
  • main_link_ids (hwIntList) – Reserved for future development
Example#
Create a spot connector at the location of node with ID 10 to connect components with IDs 3 and 4 using a tolerance of 6.0#
import hm
import hm.entities as ent
model = hm.Model()
model.CE_ConnectorCreateByMark(
    collection=hm.Collection(model, ent.Node, [10]),
    ce_style="spot",
    num_links=2,
    link_collection=hm.Collection(model, ent.Component, [3, 4]),
    link_elems_geom="elems",
    link_rule="now",
    relink_rule="none",
    tol_flag=1,
    tol=6.0,
