Model.CE_FE_SetSpecificDetail#
- Model.CE_FE_SetSpecificDetail(connector_collection, detail_type, integer_value, double_value)#
Changes a single FE realization detail for connectors on the collection.
- Parameters:
connector_collection (Collection) – The collection containing the entities need to be updated.
detail_type (int) –
The connector FE detail to edit:
1 - config (integer) - FE configuration type of the realized connector. Provided values should be >0.
Possible configs:
2 - plot
3 - weld
5 - rigid
21 - spring
55 - rigidlink
60 - bar2
61 - rod
70 - gap
104 - quads
1001 - custom
2 - tolerance (double) - Tolerance value for FE realization. Provided values should be >0.
3 - property_id (integer) - FE property ID.
4 - systems (integer: 0 or 1) - Build system flag.
Meaning:
0 - Do not build systems
1 - Build systems
5 - snap_to_node (integer: 0 or 1) - FE snap to node flag.
Meaning:
0 - Do not snap to node
1 - Snap to node
6 - remesh (integer: 0 or 1) - FE remesh flag.
Meaning:
0 - Do not re-mesh
1 - Re-mesh region
7 - force_collinear (integer: 0 or 1) - FE force collinear flag.
Meaning:
0 - Non-collinear.
1 - Collinear.
8 - fe_type (integer) - FE type value defined in the feconfig.cfg file. Provided values should be >0.
Note
See
Model.CE_FE_SetDetails(),Model.CE_FE_SetDetailsAndRealize(), andModel.CE_FE_SetSpecificDetail()for a more comprehensive description of the details.integer_value (int) – Pass necessary integers values through this parameter, that corresponds to the choice in
detail_type,with type integer.double_value (double) – Pass necessary double values through this parameter, that corresponds to the choice in
detail_type, with type double.
Note
Generally, this function is most useful to change a single previously set connector FE value. It can be used to populate all the connector’s FE values from scratch, but it is necessary that a config (or fe_type) and tolerance be properly set for realization to occur. This function makes it possible to change a single connector FE value, such as the weld config, while leaving all other FE values intact.
This function will not operate on a connector unless either the
Model.CE_FE_SetDetails()or theModel.CE_FE_SetDetailsAndRealize()function has been called first on that connector (without being rejected). Before you can update a specific FE detail (Model.CE_FE_SetSpecificDetail()), all the main FE details must be initialized (which is what the other two functions do).Example#
Initialize a connector’s FE details, and then change the tolerance from 1.0 to 2.0#import hm import hm.entities as ent model = hm.Model() connector_collection = hm.Collection(model, ent.Connector, [1, 2, 3]) model.CE_FE_SetSpecificDetail( connector_collection=connector_collection, detail_type=2, integer_value=0, float_value=2.0, )
