Model.morphalteranglevec#
Model.morphalteranglevec(h1collection, h2collection, n1, n2, n3, hold, ang, sym, con, vec)#
Alters the angle for three nodes using morphing and measuring perpendicular to a vector.
Parameters:
  • h1collection (Collection) – The collection containing the handle entities - end a.
  • h2collection (Collection) – The collection containing the handle entities - end b.
  • n1 (Entity) – The object defining the node entity - end a.
  • n2 (Entity) – The object defining the node entity - vertex.
  • n3 (Entity) – The object defining the node entity - end b.
  • hold (int) –
    Determines which of the three nodes should be held:
    0 - Hold end a
    1 - Hold end b
    2 - Hold middle
  • ang (double) – New angle between n1 and n3 with n2 as the vertex
  • sym (int) –
    Flag to determine whether or not to use symmetry:
    0 - Do not use symmetry
    1 - Use symmetry
  • con (int) –
    Flag to determine whether or not to use constraints:
    0 - Do not use constraints
    1 - Use constraints
  • vec (hwTriple) – The hwTriple object defining the vector. User can also supply a Python list of three doubles.
Example#
The handles on the collection selected interactively will be moved based on hold through an angle based on the current angle and ang, measured perpendicular to vector vec, and using n1, n2, and n3 to determine the perturbations. If symmetry is used all handles linked to marked handles by symmetry will also be perturbed. If constraints are used they will be applied to the perturbations.#
import hm
import hm.entities as ent
model = hm.Model()
model.morphalteranglevec(
    h1collection=hm.Collection(model, ent.Handle, populate=False),
    h2collection=hm.CollectionByInteractiveSelection(model, ent.Handle),
    n1=ent.Node(model, 132),
    n2=ent.Node(model,783),
    n3=ent.Node(model, 171),
    hold=0,
    ang=45.0,
    sym=1,
    con=1,
    vec=[1.0, 0.0, 0.0],
