Model.mechapplyediposition#
Model.mechapplyediposition(mode, run_solver=0)#
Applies a position to a mechanism. This will be always used in conjunction with Model.mechcontructfromedi().
The mechanism must have the enabled flag set to true for this to be possible.
Parameters:
  • mode (int) –
    The mode for the position:
    0 - Initial position
    1 - Active position
  • run_solver (int) –
    0 - Directly apply the position to bodies without considering constraints and joints.
    1 - Run the solver to apply the position along with constraints and joints.
Example#
Apply position with ID 3 on mechanism with ID 1#
import hm
import hm.entities as ent
model = hm.Model()
model.mechcontructfromedi(mode=2,param=3)
model.mechapplyediposition(mode=1,run_solver=0)
