Model.hm_latestentityid#
- Model.hm_latestentityid(entity_type, num=0)#
Returns the ID of the last created entity. An option is also available to return the ID of previously created entities (up to 99).
- Parameters:
entity_type (EntityFullType) – The type of entity to return the last created ID for.
num (int) – Queries a specific entity created previously before the last entity. The maximum is 99. Default is 0 (last entity).
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:entity (int)
Examples#
Get the latest created component#import hm import hm.entities as ent model = hm.Model() _,result = model.hm_latestentityid(entity_type=ent.Component) print("entity", result.entity)
Get the previous latest and first previous node created on line with ID 100#import hm import hm.entities as ent model = hm.Model() lines = hm.Collection(model, ent.Line, [100]) # Create two nodes on the line model.nodecreateonlines( collection=lines, number=2, bias_style=0, bias_intensity=0.0, ) # Get the last created node _, result = model.hm_latestentityid(entity_type=ent.Node, num=0) print("entity", result.entity) # Get the first previously created node _, result = model.hm_latestentityid(entity_type=ent.Node, num=1) print("entity", result.entity)
