Model.hm_metadata_byname#
Model.hm_metadata_byname(name, entity_type=EntityFullType()))#
Returns all metadata with the specified name. If entity_type is specified, all metadata with the specified name and attached to that entity type is returned.
Parameters:
  • name (hwString) – The name of the metadata entities to return the metadata.
  • entity_type (EntityFullType) – The entity type to filter the metadata by.
Returns:
  • hwReturnStatus - Status object
  • HmQueryResultList - Result list object containing HmQueryResult objects with the following output data:
    • entity (Entity) - The entity to which the metadata is attached.
    • name (hwString) - The name of the metadata.
    • value (Union[bool, str, float, int, list, numpy.ndarray, Entity, EntityList]) - The value of the metadata.
Examples#
Find all metadata named .ALTAIR.HW.CATIA.TAG#
import hm
import hm.entities as ent
model = hm.Model()
_, resultlist = model.hm_metadata_byname(name=".ALTAIR.HW.CATIA.TAG")
for result in resultlist:
    print("Entity Class:", result.entity.__class__.__name__, "| Entity ID:", result.entity.id, "| Metadata Name:", result.name, "| Metadata Value:", result.value)
Find all metadata named .ALTAIR.HW.CATIA.TAG attached to surfaces#
import hm
model = hm.Model()
_, resultlist = model.hm_metadata_byname(name=".ALTAIR.HW.CATIA.TAG", entity_type=ent.Surface)
    print("Entity ID:", result.entity.id, "| Metadata Name:", result.name, "| Metadata Value:", result.value)
