Model.midsurface_accept_edge_target_by_number#
- Model.midsurface_accept_edge_target_by_number(face, e1_edge_number, e2_line, is_opposite)#
Assigns targets for the surface edge. Once assigned, targets can be used to offset a midsurface.
- Parameters:
face (Entity) – The index of the surface to offset.
e1_edge_number (int) – The index of a line, which must be an edge of the surface to offset.
e2_line (Entity) – The index of a pilot line.
is_opposite (int) –
0 - The target is the
e2_line.1 - The target is a line located in between
e1_lineande2_line.
Note
You cannot manually employ this function, because HyperMesh must internally generate the index values (they cannot simply be typed in).
