Model.hm_collisioncheck#
- Model.hm_collisioncheck(intersected_elements=s_defaultCollection, penetrated_elements=s_defaultCollection, intersected_surfaces=s_defaultCollection, penetrated_surfaces=s_defaultCollection, penetrated_nodes=s_defaultCollection, self_check=False, reserved1=0, pair_angle=90.000000, store_segments=False, mark_adjoining=0, topo_feature_angle=0.000000, pair_results=False)#
Performs a collision detection using entities defined by
Model.hm_collisionentitycreate(). This must be preceded byModel.hm_collisoininit()and one or more calls toModel.hm_collisionentitycreate().Multiple calls to this API can be made to perform different detections.
- Parameters:
intersected_elements (Collection) – The collection that should contain any intersected element entities on output. If argument is not provided provided, no intersected elements are output. Only valid if elements or components entities are used as input entities.
penetrated_elements (Collection) – The collection that should contain any penetrated element entities on output. If argument is not provided provided, no penetrated elements are output. Only valid if elements or components entities are used as input entities.
intersected_surfaces (Collection) – The collection that should contain any intersected surface entities on output. If argument is not provided provided, no intersected surfaces are output. Only valid if surfaces or solids entities are used as input entities.
penetrated_surfaces (Collection) – The collection that should contain any penetrated surface entities on output. If argument is not provided provided, no penetrated elements are output. Only valid if elements or components entities are used as input entities.
penetrated_nodes (Collection) – The collection that should contain any penetrated node entities. If argument is not provided provided, no penetrated nodes are output. Only valid if nodes entities are used as input entities.
self_check (bool) –
False- Do not include self checks.True- Include self checks.reserved1 (int) – Reserved for future use. Must be set to 0.
pair_angle (double) – The maximum allowed angle between penetrating pair normals. Meaningful values are 0.0 <
pair_angle< 90.0. Other values disable this functionality.store_segments (bool) – Set to
Trueto store the intersection lines formed when intersection entities. Only valid whenintersected_elementsorintersected_surfacesare non-empty. The segments can then be visualized usingModel.createintersectionsegments(). Default isFalse.mark_adjoining (int) –
0 - No additional marking (default).
1 - Mark only surrounding 2D elements. Surrounded implies all of its nodes on other penetrated elements.
2 - Mark all 2D elements on topology faces containing any penetrated elements.
3 - Mark only 2D elements sharing a node with a penetrated element and on the same topo face.
topo_feature_angle (double) – The angle used to identify topo faces. If set to 0.0, the global feature angle is utilized (default).
pair_results (bool) – If set to
True, detailed pair results are calculated and the hm_collisionget functions andModel.hm_collisionwriteresultsfile()APIs can be used. If set toFalse, detailed pair results are not calculated and the hm_collisionget functions andModel.hm_collisionwriteresultsfile()APIs cannot be used (default).
- Returns:
hwReturnStatus- Status object
Examples#
Find intersect surfaces from IDs 1 - 10#import hm import hm.entities as ent model = hm.Model() checking_surfs = hm.Collection(model,ent.Surface,list(range(1,11))) intersect_surfs = hm.Collection(model,ent.Surface,populate=False) model.hm_collisioninit() model.hm_collisionentitycreate(collection=checking_surfs,dimension=0,thickness_type=1, thickness=0,edge_penetration=0,midside_nodes=0,split_quads=0, used_topology=0,grouping_identifier=False,offset=0 ) model.hm_collisioncheck(intersected_surfaces=intersect_surfs) model.hm_collisionend() print("Intersected surfaces: ", [s.id for s in intersect_surfs])
Find intersect surfaces from IDs 1 - 10 and create intersection segments#import hm import hm.entities as ent model = hm.Model() checking_surfs = hm.Collection(model,ent.Surface,list(range(1,11))) intersect_surfs = hm.Collection(model,ent.Surface,populate=False) model.hm_collisioninit() model.hm_collisionentitycreate(collection=checking_surfs,dimension=0,thickness_type=1, thickness=0,edge_penetration=0,midside_nodes=0,split_quads=0, used_topology=0,grouping_identifier=False,offset=0 ) model.hm_collisioncheck(intersected_surfaces=intersect_surfs,store_segments=True) model.createintersectionsegments(collector=0) model.hm_collisionend() print("Intersected surfaces: ", [s.id for s in intersect_surfs])
Find penetrate surfaces from IDs 1 - 10 , use the thickness assigned to the surface components#import hm import hm.entities as ent model = hm.Model() checking_surfs = hm.Collection(model,ent.Surface,list(range(1,11))) pene_surfs = hm.Collection(model,ent.Surface,populate=False) model.hm_collisioninit() model.hm_collisionentitycreate(collection=checking_surfs,dimension=0,thickness_type=1, thickness=0,edge_penetration=0,midside_nodes=0,split_quads=0, used_topology=0,grouping_identifier=False,offset=0 ) model.hm_collisioncheck(penetrated_surfaces=pene_surfs) model.hm_collisionend() print("Penetrated surfaces: ", [s.id for s in pene_surfs])
