Model.morphconstraintupdatelength#
- Model.morphconstraintupdatelength(scollection, type, mcon, nodes, vec, length, bound, color)#
Updates a model type constraint based on the length of a list of nodes.
- Parameters:
scollection (Collection) – The collection containing the shape entities.
type (int) –
0 - Measure length node to node
1 - Measure length using vector
mcon (Entity) – The morph constraint entity to update.
nodes (EntityList) – The list of node entities.
vec (hwTriple) – The hwTriple object defining the vector components. User can also supply a Python list of three doubles.
length (double) – Constrained length of node list.
bound (int) –
-1 - Greater than specified length
0 - Equal to specified length
1 - Less than specified length
color (int) – Color (1 through 64 inclusive).
Example#
Update a model type constraint for the selected node list with the option of update those nodes to be measured node to node or along a vector and the option of update the node list to be forced to be greater than , less than , or equal to the specified length#import hm import hm.entities as ent model = hm.Model() model.morphconstraintupdatelength( scollection=hm.Collection(model, ent.Shape, [1]), type=0, mcon=ent.Morphconstraint(model, 5), nodes=[ent.Node(model, 1), ent.Node(model, 2), ent.Node(model, 3)], vec=[1.0, 0.0, 0.0], length=43.5, bound=0, color=32, )
Note
The shapes on the
scollectionwill be used to force the model into compliance with the specified constraint if possible.
