Model.hm_modent_getconstraintruleoptions#
Model.hm_modent_getconstraintruleoptions()#
Returns a list of options that control the behavior of add/move/remove operations for a subsystem entity. Valid entity combinations are:
Independent Entity Types
Dependent Entity Types
beamsectcols
beamsects
components
elements
components
materials
components
nodes
components
properties
loadcols
loads
materials
curves
properties
materials
systcols
systems
vectorcols
vectors
Returns:
  • hwReturnStatus - Status object
  • HmQueryResultList - Result list object containing HmQueryResult objects with the following output data:
    • independent_type (EntityFullType)
    • dependent_info (HmQueryResultList)-Result list object containing HmQueryResult objects with the following output data:
      • dependent_type (EntityFullType)
      • constraint_rule_options (EntityFullType) (HmQueryResult)-Result object with the following output data:
      • add_move_remove (unsigned int) - has values 0 (false) and 1 (true)
      • add_move_remove_shared (unsigned int) - has values 0 (forbid whole action), 1 (do not move shared), or 2 (move shared)
Example#
Get the options that control the behavior of add / move / remove operations for a subsystem entity#
import hm
import hm.entities as ent
model = hm.Model()
_,resultList = model.hm_modent_getconstraintruleoptions()
for result in resultList:
    print("independent_type", result.independent_type)
    infoList = result.dependent_info
    for info in infoList:
        print("dependent_type", info.dependent_type)
        constrain = info.constraint_rule_options
        print("add_move_remove", constrain.add_move_remove)
        print("add_move_remove_shared", constrain.add_move_remove_shared)
