Model.hm_getactiveplotcontrolmaxvalue#
- Model.hm_getactiveplotcontrolmaxvalue(plot_type, collection)#
Returns the maximum value for the active plot control together with the entity. There can be only one active plot control for every plot type.
- Parameters:
plot_type (hwString) – The type of plot for which the result values are queried. Valid values are contour, vector, and tensor.
collection (Collection) – The collection containing the entities that are considered for evaluation.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:entity (Entity) - The entity for which the maximum value is returned.
value (float) - The maximum value for the active plot control.
Note
If the function is used as part of a script that creates the queried plot, it is required to call Model.hm_redraw before using this function to ensure the graphics are refreshed and the data can be extracted.
Example#
Get the maximum value for the active contour plot control for a collection of displayed nodes#import hm import hm.entities as ent model = hm.Model() nodes = hm.CollectionByDisplayed(model, ent.Node) _, result = model.hm_getactiveplotcontrolmaxvalue(plot_type="contour", collection=nodes) print("Entity ID:", result.entity.id) print("Maximum Value:", result.value)
