Model.hm_collisiongetcomponentlinesegment#
- Model.hm_collisiongetcomponentlinesegment(component_index, linesegment_index, include_ignored=False)#
Returns the line segment coordinates for a component collision pair. Once the call to the relevant hm_collision* functions to generate the collision data is made, this function can follow. In addition, the
pair_resultsargument toModel.hm_collisioncheck()must be set toTrue.For each intersecting type of collision, there is a list of pairs of intersecting components. For each intersecting component pair, there is a list of intersection line segments.
To execute this function, the below sequence of data collection is required:
Get the number of colliding component pairs
Get the component IDs for each component pair
Get the number of intersected entities for each component pair
- Parameters:
component_index (int) – The index of the component pair to query, starting from 0. The total number of component pairs for a specific
collision_typecan be found usingModel.hm_collisiongetcomponentpaircount().linesegment_index (int) – The index of the line segment to query, starting from 0. The total number of entity pairs for a specific component_index can be found using
Model.hm_collisiongetcomponentlinesegmentcount().include_ignored (bool) –
Specifies if results ignored when the
allowable_depthvalue which is specified viaModel.hm_collisioninit()should be reported or not:False - Do not include ignored results (default).
True - Include ignored results.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:lineSegment1 (numpy.ndarray) - x,y,z-coordinates of line segment’s start.
lineSegment2 (numpy.ndarray) - x,y,z-coordinates of line segment’s end.
Example#
Create nodes at the center of intersection line segments for intersect components with ID 1 and 2#import hm import hm.entities as ent model = hm.Model() model.hm_collisioninit(tolerance=10**(-5)) comp_collection_1 = hm.Collection(model,ent.Element,hm.Collection(model,ent.Component,[1])) comp_collection_2 = hm.Collection(model,ent.Element,hm.Collection(model,ent.Component,[2])) model.hm_collisionentitycreate( collection=comp_collection_1, dimension=0, thickness_type=0, thickness=0, edge_penetration=0, midside_nodes=0, split_quads=0, used_topology=0, grouping_identifier=False, offset=0 ) model.hm_collisionentitycreate( collection=comp_collection_2, dimension=0, thickness_type=0, thickness=0, edge_penetration=0, midside_nodes=0, split_quads=0, used_topology=0, grouping_identifier=False, offset=0 ) int_elems = hm.Collection(model,ent.Element,populate=False) model.hm_collisioncheck(intersected_elements=int_elems,store_segments=True,pair_results=True) _, result = model.hm_collisiongetcomponentpaircount(collisionType=0) component_pair_count = result.numberOfCollisionPairs if component_pair_count > 0: for i in range(0,component_pair_count): _, result = model.hm_collisiongetcomponentlinesegmentcount(comp_index=i) linesegmentcount = result.numberOfLineSegments if linesegmentcount!=0: for j in range(0,linesegmentcount): _, result = model.hm_collisiongetcomponentlinesegment(component_index=i,linesegment_index=j) linesegments_start = result.lineSegment1 linesegments_end = result.lineSegment2 curr_x = (linesegments_start[0] + linesegments_end[0])/2 curr_y = (linesegments_start[1] + linesegments_end[1])/2 curr_z = (linesegments_start[2] + linesegments_end[2])/2 # Creating node with global coordinates calulated from above ent.Node(model,globalx=curr_x, globaly=curr_y, globalz=curr_z) model.hm_collisionend()
