Model.blmesh_2d2#
- Model.blmesh_2d2(base_collection, num_layers, first_layer_thickness, growth_rate, element_size=0.0, element_type='', BL_reduction=0, DefaultBLSelection='With_BL', Auto_BL_reduction=0, CoreToBLThicknessRatio=0.0, CornerFactor=0.0, ElemsToSurfComp=0)#
Generates a 2D boundary layer mesh on boundary layer edges, with specified parameters.
Non-boundary layer information is specified using the
blmesh_2d_input_nonbl()and boundary layer information is specified usingblmesh_2d_input_bl(). Ifblmesh_2d_input_nonbl()is not called beforeblmesh_2d2(), then all edges of the selected region are considered as boundary layer edges.- Parameters:
base_collection (Collection) – The collection containing the entities to use for the base. Valid entities are surfaces and elements.
num_layers (int) – The number of boundary layers to generate.
first_layer_thickness (double) – The thickness value of the first layer.
growth_rate (double) – The growth rate of the boundary layers.
element_size (double) – The core mesh element size.
element_type (hwString) – The core mesh element type.
BL_reduction (int) – Option to reduce BL (Boundary Layer) during meshing.
DefaultBLSelection (hwString) – Default BL/non-BL selection for all boundary edges. Valid values are With_BL, Without_BL_fixed, Without_BL_remesh.
Auto_BL_reduction (int) – Option to auto reduce BL during meshing.
CoreToBLThicknessRatio (double) – Ratio of core mesh to BL thickness, which is used for BL reduction.
CornerFactor (double) – A dimensionless value used for corner management. The range is 0.1-1.0 for thinner BL thickness, and 1.0-10.0 for thicker BL thickness.
ElemsToSurfComp (int) – Option to organize new elements to surface components.
Example#
Create a 5 layer boundary mesh with a quad dominated mesh of size 2.0 on surface with ID 10 , with the first layer be 0.15 thick and a growth rate of 1.2 , use boundary layer elements with IDs 10 and 11 as fixed and 12 and 13 as float , and non - boundary layer elements with IDs 1 and 2 as fixed and 5 and 6 as float#import hm import hm.entities as ent model = hm.Model() # Boundary layer elements blFixedEl_collection = hm.Collection(model, ent.Element, [10, 11]) blFloatEl_collection = hm.Collection(model, ent.Element, [12, 13]) model.blmesh_2d_input_bl( fixed_collection=blFixedEl_collection, float_collection=blFloatEl_collection ) # Non-Boundary layer elements nonBlFixedEl_collection = hm.Collection(model, ent.Element, [1, 2]) nonBlFloatEl_collection = hm.Collection(model, ent.Element, [5, 6]) model.blmesh_2d_input_nonbl( fixed_collection=nonBlFixedEl_collection, float_collection=nonBlFloatEl_collection ) # Generate the Boundary layer mesh base_surf_collection = hm.Collection(model, ent.Surface, [10]) model.blmesh_2d2( base_collection=base_surf_collection, num_layers=5, first_layer_thickness=0.15, growth_rate=1.2, element_size=2.0, element_type="quads", )
