Model.imprint_elements#
- Model.imprint_elements(collection_target, collection_source, options)#
Imprints, connects and optionally remeshes source 1D/2D elements onto target 2D elements.
- Parameters:
collection_target (Collection) – The collection containing the target (destination) entities to imprint onto. Valid entities are components and elements.
collection_source (Collection) – The collection containing the entities.
options (hwString) –
Additional strings defining extended parameters/options. Options are defined in
"name value(s)"format. Valid options are:projection_vector
The 3 doubles defining the vector direction. If not defined, normal projection is used.
remain
1 - Source remains, source node coordinates are kept (default if not provided).
2 - Destination remains, node coordinates projected to destination are used.
3 - Both remain, source entities are projected and a copy is imprinted to destination.
max_distance
The function will exit with an error if the distance between source and destination exceeds this value. If not specified, this is ignored.
to_dest_component
0 - Do not organize imprinted elements to destination component (default if not provided).
1 - Organize imprinted elements to destination component.
angle
The angle used to define feature edges on the mesh. If not defined, 25.0 is used.
remesh_mode
-1 - No remesh. Element connectivity is maintained by recovery of the imprinting element edges.
0 - Do not remesh destination. Destination mesh is stitched to maintain element connectivity.
1 - Remesh all input destination elements.
2 - Remesh destination elements defined by remesh_layers.
remesh_layers
Must be defined if remesh_mode is 2.
0 - Remesh only the elements attached to the border of the imprinted element image.
> 0 - Remesh additional layers in addition to the elements attached to the imprinted element image.
mesh_type
Automatically detected from input mesh if not provided. Valid values are:
0 - tria
1 - quad
2 - mixed
3 - R-tria
4 - quad only
mesh_size
create_joint_elems
Only valid when remain is 3.
0 - Do not generate patch elements between source and destination elements (default if not provided).
1 - Generate patch elements between source and destination elements.
Example#
Imprint elements from component named “conn_imprint” to component named “auto1”, using a normal projection, a feature angle of 30, keeping the source, and remeshing the destination using 2 layers#import hm import hm.entities as ent model = hm.Model() target_component_collection = hm.Collection(model, ent.Component, "name=auto1") source_component_collection = hm.Collection(model, ent.Component, "name=conn_imprint") model.imprint_elements( collection_target=target_component_collection, collection_source=source_component_collection, options="remain 1 remesh_mode 2 remesh_layers 2 angle 30.0", )
