Model.external_skin_extraction#
- Model.external_skin_extraction(collection, mode, min_size, max_size, extraction_mode, seed_point_coordinates, target_point_coordinates, baffle_detection, min_surface_area, mc_collection, graphicsDB=0)#
Detects leaks and extracts exposed exterior or interior faces and surfaces.
- Parameters:
collection (Collection) – The collection containing the inout entities.
mode (int) –
The detection mode.
1 - Leak detection only.
2 - Leak detection with skin extraction. If a leak is detected, the skin is not extracted.
3 - Skin extraction without leak detection.
4 - Leak detection with gap filling.
min_size (double) – Leaks smaller than
min_sizewill be ignored. Highermin_sizevalues can lead to longer skin extraction time.max_size (double) – This value should be set to 0.0.
extraction_mode (int) –
The extraction mode.
1 - Exterior skin extraction.
2 - Interior (cavity) skin extraction.
seed_point_coordinates (hwString) – String containing the x, y, z coordinates of the seed point defined within the target volume for leak detection. The point should be located inside the cavity, not close to the volume boundaries.
target_point_coordinates (hwString) – String containing the x, y, z coordinates of the seed point defined outside the target volume for leak detection. The point should be located outside the cavity not close to the volume boundaries.
baffle_detection (int) –
The baffle detection mode.
0 - No baffles detected.
1 - Only external baffles are detected.
2 - Only internal baffles are detected.
3 - Both external and internal baffles are detected.
min_surface_area (double) – Defines the percentage of the skin area. For surface input, if the exposed area of the detected surfaces is less than the user-defined percentage of the total area, the surfaces are not marked as skin.
mc_collection (Collection) – The collection containing the meshcontrol entities.
graphicsDB (int) – Reserved for future development.
Example#
Detect a leak bigger than 20.0 and extract the exterior skin from displayed elements define a volume around a point with coordinates (2690.0, 0.0, 830.0) with minimal surface area set to 10 %#import hm import hm.entities as ent model = hm.Model() elements = hm.CollectionByDisplayed(model, ent.Element) model.external_skin_extraction( collection=elements, mode=2, min_size=20.0, max_size=0.0, extraction_mode=1, seed_point_coordinates="2690.0 0.0 830.0", target_point_coordinates, baffle_detection=0, min_surface_area=10.0, mc_collection=hm.Collection(model,ent.Meshcontrol,populate=False) )
