Model.elementtesttimestep#
Model.elementtesttimestep(collection, time_beam, time_spring, time_shell, time_solid, time_tshell, output_collection, dimension, contour, added_mass, title)#
Tests beam, spring, shell, solid and thick shell elements using the time step element quality check.
Parameters:
  • collection (Collection) – The collection containing the element entities to test.
  • time_beam (double) – The value to use as a threshold beyond which beam elements should be considered to have failed the test.
  • time_spring (double) – The value to use as a threshold beyond which spring elements should be considered to have failed the test.
  • time_shell (double) – The value to use as a threshold beyond which shell elements should be considered to have failed the test.
  • time_solid (double) – The value to use as a threshold beyond which solid elements should be considered to have failed the test.
  • time_tshell (double) – The value to use as a threshold beyond which thick shell elements should be considered to have failed the test.
  • output_collection (Collection) – The collection containing the failed element entities.
  • dimension (int) –
    A code to measure the dimension of:
    1 - Measure 1D (beam and spring) elements only.
    2 - Measure 2D (shell) elements only.
    4 - Measure 3D (solid) elements only.
    6 - Measure 2D (shell) and 3D (solid) elements.
    7 - Measure all elements
  • contour (int) –
    Flag that determines how the results are presented. Valid values are:
    0 - Display the results of the test normally.
    1 - Display the elements color coded by their ratings.
  • added_mass (int) –
    A flag indicating what to contour.
    0 - Time step
    1 - Added mass, when contour is set to 1.
  • title (hwString) – The title for the contour, when contour is set to 1.
Examples#
Testing all displayed shell elements for a time step of 0.0001#
import hm
import hm.entities as ent
model = hm.Model()
elems1 = model.CreateCollectionByDisplayed(ent.Element)
elems2 = hm.Collection(model, hm.FilterByEnumeration(ent.Element, ids=hm.hwUIntList([])))
model.elementtesttimestep(
        collection=elems1,
        time_beam=0,
        time_spring=0,
        time_shell=0.0001,
        time_solid=0,
        time_tshell=0,
        output_collection=elems2,
        dimension=2,
        contour=0,
        added_mass=0,
        title=""
Testing all displayed shell and solid elements for a time step of 0.0001 and display a contour#
import hm
model = hm.Model()
        collection=elems1,
        time_beam=0,
        time_spring=0,
        time_shell=0.0001,
        time_solid=0,
        time_tshell=0,
        dimension=6,
        contour=1,
        added_mass=0,
        title=""
