Model.linemesh_savedata_bar1#
Model.linemesh_savedata_bar1(entity_type, create_flag, config, property_id, vector, offset_x_a, offset_y_a, offset_z_a, offset_x_b, offset_y_b, offset_z_b, auto_flag, organize)#
Creates 1D elements, with options for bar2 elements, and cleans up memory.
Each call to this function must be paired with a previous call to Model.linemesh_preparedata1() or Model.linemesh_preparenodeslist1().
Parameters:
  • entity_type (EntityFullType) – The type of entity to 1D mesh. Valid values are lines and nodes.
  • create_flag (int) –
    Flag for generating elements:
    0 - Do not generate elements.
    1 - Generate elements.
  • config (int) – The 1D element config ID of the elements to create. For bar2 elements, this should be set to 60.
  • property_id (int) – The ID of the property to assign to the 1D elements.
  • vector (hwTriple) – The hwTriple object defining the y-axis vector components. User can also supply a Python list of three doubles. This argument is only used if auto_flag=0 and config=60.
  • offset_x_a (double) – The offset in the x-direction at end a. This argument is only used if config=60.
  • offset_y_a (double) – The offset in the y-direction at end a. This argument is only used if config=60.
  • offset_z_a (double) – The offset in the z-direction at end a. This argument is only used if config=60.
  • offset_x_b (double) – The offset in the x-direction at end b. This argument is only used if config=60.
  • offset_y_b (double) – The offset in the y-direction at end b. This argument is only used if config=60.
  • offset_z_b (double) – The offset in the z-direction at end b. This argument is only used if config=60.
  • auto_flag (int) – If set to 0, vector is used. Otherwise, vector type is set to auto. This argument is only used if config=60.
  • organize (int) –
    Organizing new 1D elements:
    0 - Organize new 1D elements to current component.
    1 - Organize new 1D elements to input lines component(s).
Examples#
Mesh lines with IDs 15 and 18 with a 30 degree break angle, creating bar2 elements with no property or offset and using the auto vector#
import hm
import hm.entities as ent
model = hm.Model()
# Creating a collection of line entities which we will
# prepare for 1D meshing.
line_collection = hm.Collection(model, ent.Line, [15, 18])
model.linemesh_preparedata1(collection=line_collection, break_angle=30.0, config=60)
# Assing meshing parameters to line segments for 1D meshing.
model.linemesh_saveparameters(segment=0, density=3, bias=0, bias_style=0)
model.linemesh_saveparameters(segment=1, density=2, bias=0, bias_style=0)
# Creating 1D (bar2) elements with no property or offset
# and using the auto vector
model.linemesh_savedata_bar1(
    entity_type=ent.Line,
    config=60,
    property_id=0,
    vector=None,
    offset_x_a=0.0,
    offset_x_b=0.0,
    offset_y_a=0.0,
    offset_y_b=0.0,
    offset_z_a=0.0,
    offset_z_b=0.0,
    auto_flag=1,
    organize=0,
Mesh between nodes with IDs 16 , 17 , and 2 with 3 rigid elements between nodes with IDs 16 and 17 and with 2 rigid elements between nodes with IDs 17 and 2 , with no property assignment , organize to the input line component(s )#
import hm
model = hm.Model()
# Creating a collection of node entities which we will
node_list = [ent.Node(model, 16), ent.Node(model, 17), ent.Node(model, 2)]
model.linemesh_preparenodeslist1(list=node_list, config=5)
# Creating 1D elements with no property
# and using the auto vector, organizing to the input line component(s)
    entity_type=ent.Node,
    config=5,
    property_id=0,
    vector=None,
    offset_x_a=0.0,
    offset_x_b=0.0,
    offset_y_a=0.0,
    offset_y_b=0.0,
    offset_z_a=0.0,
    offset_z_b=0.0,
    auto_flag=1,
    organize=1,
