Model.hm_visualizeloads#
- Model.hm_visualizeloads(entities, config, plottype, showlabel=0, locationentitytype=EntityFullType())#
Plots engineering loads referenced by a load collector honoring the scale factor defined in the collector.
- Parameters:
entities (Collection) – The collection containing the load entities.
config (int) – The config of the load to be reviewed.
plottype (int) –
The requested plot type. A validation is performed for the referred loads to ensure they are valid for the specified plot type.
0 - Clear all graphics
1 - Vector plot
2 - Interactive scalar plot
3 - Static scalar plot
showlabel (int) –
The labels for the vector plot. The display of labels is also dependent on the global load handle flag.
0 - Off
1 - On
locationentitytype (EntityFullType) – The entity type where the load is applied. If specified, only the loads which are applied on the specified entity type will be reviewed. Valid values are nodes and elements.
- Returns:
hwReturnStatus- Status object
Examples#
Create a vector plot of force loads in all load collectors with labels#import hm import hm.entities as ent model = hm.Model() all_loadcols = hm.Collection(model, ent.Loadcol) model.hm_visualizeloads( entities=all_loadcols, config=1, plottype=1, showlabel=1, locationentitytype=ent.Node )
Create a scalar plot of temperature loads referenced by load collectors with IDs 1 - 10 applied on nodes#import hm import hm.entities as ent model = hm.Model() loadcols = hm.Collection(model, ent.Loadcol, list(range(1,11))) model.hm_visualizeloads( entities=loadcols, config=1, plottype=5, showlabel=0, locationentitytype=ent.Node )
Create all graphics#import hm import hm.entities as ent model = hm.Model() all_loadcols = hm.Collection(model, ent.Loadcol) model.hm_visualizeloads( entities=all_loadcols, config=1, plottype=0 )
