Model.morphnodesmeshoffset#
Model.morphnodesmeshoffset(m_collection, e_collection, f_collection, t_collection, nproj, c_vec, integ, mbias, fbias, envelope, undisplayed, offset)#
Moves the selected nodes to a mesh. The moving nodes may be projected to the mesh along a vector, normal to the mesh, or normal to any elements attached to the nodes. The fixed nodes are held in place and the affected elements (or all unfixed nodes in the model if integ is 3 or 6) are stretched according to the value of integ.
Temporary handles are created for all moving and fixed nodes to determine the stretching of the affected elements. If integ is 0, a general domain is temporarily created for the affected elements. If integ is 1, the domains currently in the model are used. If integ is 2, 1D, 2D, 3D, and edge domains are temporarily created for the affected elements but the 2D domains are not partitioned. If integ is 3, then handle influences are applied using a spatial relationship rather than through a domain. If integ is 4, only the selected moving nodes are moved and all others are held fixed. If integ is 5, 1D, 2D, 3D, and edge domains are temporarily created for the affected elements and the 2D domains are partitioned. Any handles created due to partitioning are moved based on their distance from the moving and fixed nodes. If integ is 6, then handle influences are applied using the Kriging algorithm. If integ is 7, then handle influences extend only up to a given distance (if envelope is positive) or a given multiple of the applied perturbations (if envelope is negative) away from the moving nodes.
The bias factors function as they would for handles except that all moving nodes will have the mbias value and all fixed nodes will have the fbias value.
If no elements are selected and nproj is 2, 5 or 6 all elements in the model are used to determine projection vectors.
If integ is set to 3, 6, or 7, nodes on undisplayed elements and components can be morphed, fixed, or excluded depending on the value of undisplayed.
If offset is non-zero, the moving nodes will be offset from the mesh by the specified amount.
Parameters:
  • m_collection (Collection) – The collection containing the moving node entities. The only valid entities are nodes.
  • e_collection (Collection) – The collection containing the affected element entities. The only valid entities are elements.
  • f_collection (Collection) – The collection containing the fixed node entities. The only valid entities are nodes.
  • t_collection (Collection) – The collection containing the target elements entities. The only valid entities are elements.
  • nproj (int) –
    Flag for projecting normal option. Valid options are:
    0 or 10 - Project normal to vector c_vec
    1 or 11 - Project along c_vec
    2 or 12 - Project normal to attached elements
    5 or 15 - Project normal to attached elements using smoothed normals
    6 to 16 - Project normal to attached elements using CFD corners
    If offset is non-zero, the offset will be measured from the closest point on the mesh for values of 0, 1, 2, 5 and 6. The offset will be measured along the projection vector or normal for values of 10, 11, 12, 15, and 16.
  • c_vec (hwTriple) – The hwTriple object defining the vector components for the projectiopn direction. User can also supply a Python list of three doubles.
  • integ (int) –
    0 - Free edges (a single general domain)
    1 - Use existing domains
    2 - Inferred edges (1D, 2D, 3D, and edge domains - no partitioning)
    3 - Morph all nodes using a proximity algorithm
    4 - Morph all moving nodes and fix the unselected nodes
    5 - Partitioned edges (1D, 2D, 3D, and edge domains with partitioning)
    6 - Morph all nodes using the Kriging algorithm
    7 - Morph all nodes within an envelope around the moving nodes
  • mbias (double) – Bias factor of moving nodes.
  • fbias (double) – Bias factor of fixed nodes.
  • envelope (double) –
    If positive, all nodes beyond the given distance away from the moving nodes will be fixed.
    If negative, all nodes beyond a distance calculated by multiplying the total perturbation of each moving node by the absolute value of the envelope and extended away from each moving node will be fixed.
    If integ=7, the calculated distance defines an envelope around the moving nodes within which the morphing of those nodes will linearly taper from fully matching the nearest moving node to zero at the edge of the envelope. If any fixed nodes are within the envelope they will also reduce the morphing of nearby nodes.
  • undisplayed (int) –
    If integ is set to 3, 6, or 7, nodes which are not displayed can be affected by the morphing. This defines how undisplayed nodes are handled. Valid options are:
    0 - Morph nodes on undisplayed elements
    1 - Fix nodes on undisplayed elements, they will function just like nodes on the f_collection
    2 - Exclude nodes on undisplayed elements, they will not be morphed nor affect the morphing
  • offset (double) – The distance to offset nodes from the target. The offset will be measured from the closest point on the target mesh for values of nproj of 0, 1, 2, 5 and 6. The offset will be measured along the projection vector normal for values of nproj of 10, 11, 12, 15 and 16.
Example#
Move a collection of nodes to be offset 1.2 from a mesh normal to the mesh and stretch all the elements in the model use the exist domains#
import hm
import hm.entities as ent
model = hm.Model()
moving_nodes_collection = hm.Collection(model, ent.Node, [11, 12, 13])
affected_elems_collection = hm.Collection(model, ent.Element, list(range(1, 101)))
fixed_nodes_collection = hm.Collection(model, ent.Node, [21, 22, 23])
target_elems_collection = hm.Collection(model, ent.Element, list(range(101, 201)))
model.morphnodesmeshoffset(
    m_collection=moving_nodes_collection,
    e_collection=affected_elems_collection,
    f_collection=fixed_nodes_collection,
    t_collection=target_elems_collection,
    nproj=0,
    c_vec=[1.0, 0.0, 0.0],
    integ=1,
    mbias=1.0,
    fbias=1.0,
    envelope=0.0,
    undisplayed=0,
    offset=1.2,
