Model.solid_cavity_detect_modify_surfaces#
- Model.solid_cavity_detect_modify_surfaces(collection, region_id, add_surfs_flag)#
Modify a partially detected cavity by adding and removing surfaces.
The function
Model.solid_cavity_detect_start()must be called before calling this function to generate the cavities as region entities.- Parameters:
collection (Collection) – The collection containing the surface entities to add or remove.
region_id (unsigned int) – The ID of the region containing the cavity definition to modify.
add_surfs_flag (int) –
0 - The input surfaces are removed from the cavity.
1 - The input surfaces are added to the cavity.
Examples#
Add surfaces with IDs 10 and 23 to a cavity attached to the region with ID 5#import hm import hm.entities as ent model = hm.Model() model.solid_cavity_detect_start( collection=hm.Collection(model, ent.Surface, [10, 23]), all_cavities=1, get_n_cavities=0, max_radius=-1, max_length=-1, min_concavity=0.5, ) model.solid_cavity_detect_modify_surfaces( collection=hm.Collection(model, ent.Surface, [10, 23]), region_id=5, add_surfs_flag=1, ) model.solid_cavity_detect_end()
Remove the surfaces with IDs 10 and 23 to a cavity attached to the region with ID 5#import hm import hm.entities as ent model = hm.Model() model.solid_cavity_detect_start( collection=hm.Collection(model, ent.Surface, [10, 23]), all_cavities=1, get_n_cavities=0, max_radius=-1, max_length=-1, min_concavity=0.5, ) model.solid_cavity_detect_modify_surfaces( collection=hm.Collection(model, ent.Surface, [10, 23]), region_id=5, add_surfs_flag=0, ) model.solid_cavity_detect_end()
