Model.CE_EditSeamAndLineDetail#
- Model.CE_EditSeamAndLineDetail(ce_collection, density=0, spacing=0.0, half_spacing_offset=0, offset=0.0, param1=0, param2=0.0, vertex_angle=0.0)#
Edit density, spacing and offset details for seam or line spot connectors specified by collection.
- Parameters:
ce_collection (Collection) – The collection containing the connector entities to be updated.
density (unsigned int) – Integer number to split line into number of points. Spacing between points (=line_length/density).
spacing (double) – Float number to split line into number of points with specified distance between points.
half_spacing_offset (unsigned int) –
Create points from an offset (=
spacing/2) from the start and end of line.0 - Follows the spacing provided by
offsetparameter1 - Follows the spacing in parameter description (
half_spacing_offset)offset (double) – Create points from an offset from the start and end of line.
param1 (unsigned int) – Reserved for future use. It must be 0.
param2 (double) – Reserved for future use. It must be 0.0.
vertex_angle (double) – Reserved for future development.
Note
Instead of this function the
Model.CE_DetailSetInt()andModel.CE_DetailSetDouble()are recommended for the purpose of setting details for a seam connector.Example#
Setdensity=10andoffset=1.5for line connectors with IDs 1, 2 and 3#import hm import hm.entities as ent model = hm.Model() connector_collection = hm.Collection(model, ent.Connector, [1, 2, 3]) model.CE_EditSeamAndLineDetail( ce_collection=connector_collection, density=10, offset=1.5 )
Note
The specified details are modified, only if the previous values were not the same. The modified connectors are unrealized since editing details affects realization.
