Model.tableinsertcolumn#
- Model.tableinsertcolumn(name, data_type, column_label, string_array, column_index)#
Inserts a column of data into a table.
- Parameters:
name (hwString) – The name of the table to update.
data_type (hwString) – The data type of the column. See
Model.tablecreate()for valid values.column_label (hwString) – The label of the column.
string_array (hwStringList) – The string array that contains the column data to add. The length of the list should be equal to the number of rows in the table.
column_index (unsigned int) – The index of the column to insert. Tables are indexed starting from 1 (1 to n columns).
Example#
Insert column 4 of type integer and label INTEGERS to “ table1 “ which has 7 rows#import hm import hm.entities as ent model = hm.Model() model.tableinsertcolumn( name="table1", data_type="int", column_label="INTEGER", string_array=["1", "2", "3", "4", "5", "6", "7"], column_index=4, )
