Model.hm_plotshape_byentity#
- Model.hm_plotshape_byentity(id, shape, height=1.0, L1=1.0, L2=1.0, L3=1.0, r1=3.0, r2=3.0, r3=3.0, color=1, drawmode=1, transparency=0.0, system=0)#
Creates a graphical shape.
- Parameters:
id (Entity) – The entity object to create the shape on.
shape (hwString) – The shape to create. Valid values are box, cone, cylinder, ellipsoid, frustum and sphere.
height (double) – The height for
shapeset to cone, cylinder, or frustum.L1 (double) – The x-component for
shape="box".L2 (double) – The y-component for
shape="box".L3 (double) – The z-component for
shape="box".r1 (double) – The radius for
shapeset to cone, cylinder, or sphere. The x-component forshape="ellipsoid". The top radius forshape="frustum".r2 (double) – The y-component for
shape="ellipsoid". The bottom radius forshape="frustum".r3 (double) – The z-component for
shape="ellipsoid".color (int) – The color to use for the shape. Valid values are 1-64.
drawmode (int) –
The draw mode.
0 - Wireframe
1 - Line with mesh
2 - Only mesh
transparency (double) – The transparency of the shape. If not specified, no transparency is used.
system (int) – The coordinate system to which the shape must be oriented. Default is global system.
- Returns:
hwReturnStatus- Status object
Example#
Create a box shape with dimensions 10x15x20 on node 5#import hm import hm.entities as ent model = hm.Model() node = ent.Node(model,5) model.hm_plotshape_byentity(node,"box",L1=10.0,L2=15.0,L3=20.0)
