Model.propagatesplithexas#
- Model.propagatesplithexas(splittype, startelement, n1, n2)#
Given a hexa element and two nodes diagonally across a face of that element, splits the hexa according to a set pattern and propagates that split to any hexa adjoining the opposite face of the hexa and so on through the displayed elements of the database.
- Parameters:
splittype (int) –
A number between 1 and 6 identifying the splitting pattern to use.
1 - Two pentas (split along the diagonal formed by
n1andn2).2 - Penta & hexa (with the penta to the left of the diagonal).
3 - Hexa & penta (with the penta to the right of the diagonal).
4 - Two hexas (split from the right of
n1to the left ofn2).5 - Three hexas (split from
n1to both sides adjacent ton2).6 - Four hexas (split in a plus pattern).
startelement (Entity) – The starting hexa element entity.
n1 (Entity) – One of the nodes entity defining the starting face of the hexa.
n2 (Entity) – The other node entity defining the starting face of the hexa.
Example#
Split a column of hexas into paired pentas start with element with ID 205 , where nodes with IDs 1015 and 1017 are diagonally opposite from each other across one face of the hexa#import hm import hm.entities as ent model = hm.Model() model.propagatesplithexas( splittype=1, startelement=ent.Element(model, 205), n1=ent.Node(model, 1015), n2=ent.Node(model, 1017), )
Note
The hexa elements can be first or second order and need not all be the same order.
